Sometimes this happens on my Mac. This rarely happens and currently haven’t found any robust procedure to reproduce this.
Layer merged to “Default” on save.
Does not affect behaviour unless the file is closed.
File icon (thumbnail on Finder, Quicklook) isn’t affected, showing objects with color assigned to existing layers.
Unit changed to “micrometers” on save. Does not affect behaviour unless the file is closed.
wim
(Wim Dekeyser)
April 29, 2021, 8:41am
2
Hi -
I don’t recall having run into those behaviors before.
Are you running any non-default plug-ins?
I don’t think any non-default plugin is installed.
If needed I can send you the corrupt file.
(ps. pluginmanager
→ plug-ins that do not ship with Rhino
crashed)
wim
(Wim Dekeyser)
April 29, 2021, 9:38am
4
Hi -
I can’t say that’s normal either…
Could you please run the Rhino SystemInfo
command and copy-paste the result here?
Also, are you sending in the crash report when Rhino crashes?
Here is the result of SystemInfo
I didn’t send any crash report because Rhino did not crash on corrupt file save.
Rhino 7 SR5 2021-4-10 (Rhino 7, 7.5.21100.03002, Git hash:master @ 2cd158094b595f6400479d7cbe511454b6149527)
License type: Commercial, build 2021-04-10
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 11.0.1 (Build 20B29) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro14,3
Language: en-GB (MacOS default)
AMD Radeon Pro 555 OpenGL Engine (OpenGL ver:4.1 ATI-4.0.47)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 2 GB
Graphics: Radeon Pro 555
Displays: DELL U2720QM (218dpi 2x), Color LCD (258dpi 2x)
Graphics processors
Intel HD Graphics 630 (1536 MB)
Radeon Pro 555 (2 GB)
Color LCD (1680 x 1050)
DELL U2720QM (2560 x 1440 @ 60Hz)
USB devices
Apple Inc.: Apple T1 Controller
Logitech: USB Receiver
ARCHISS PTR21: ARCHISS PTR21
kymok: shirabiso
Bluetooth devices
None
Third party kernel extensions
com.intel.driver.EnergyDriver (3.7.0) 35E739F9-BF6C-3024-A67C-750711B3FB64
Third party plugins
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 7.5.21100.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 7.5.21100.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 7.5.21100.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp "Displacement" 7.5.21100.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp "Legacy Rhino Render" 7.5.21100.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp "Import_OBJ" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp "export_xaml" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp "QuadRemesh" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp "export_OBJ" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp "Export SVG" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp "Export_DAE" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp "PDF Export" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp "IGES Export Plug-in" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp "Import_SVG" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp "BlockEdit" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp "Export_AMF" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp "Import_DST" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp "PLY - Polygon File Format Export" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp "Import_AMF" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 7.5.21100.3002
