Layer Import function
Is there an option to import just the layer structure from another Rhino file, excluding the objects? Similar to importing Cplanes, named views, etc., from other Rhino files. This would be a valuable and essential feature.
Thanks to @Helvetosaur. The script allowed me to import the layers from another file without the objects.
I also tried to make a script that allows you to select the layers you want to import. But I don’t understand scripts very well. It doesn’t work with sublayers. If anyone wants to continue I’ll leave the draft here.
LayersImportSelected.py (904 Bytes)
