The current sr and last sr I noticed a regression in how long it takes to get rendered mode to work.
I have two files where I experience slow load times to get into rendered mode. One is 289 meg and the other is 271 meg.
I never save files or rarely with a rendered view active.
When I first open a file and that file has viewports set to wireframe if I click on the “standard default rendered mode” for a viewport it now takes over 3 minutes for rhino to show the scene in rendered mode. But after this big lag if I go back to wireframe and then back to rendered mode it now only takes seconds to get into rendered mode. Seems there is something going on that is taking longer than it was 2 srs back when first opening a file.
Oddly the same happens when I go to render in cycles. For the first render it takes 3 minutes or more for that first cycles screen to appear it seems to the user rhino doesn’t appear to be working but if I wait rhino renders the cycles window finally appearing after 3 minutes. If I render again after this first rendering the cycles window only takes 8 seconds to load or appear on screen.
Kind of an annoyance as it gets worse in my other slightly larger file.
RM
Rhino 7 SR34 2023-9-24 (Rhino 7, 7.34.23267.11001, Git hash:master @ a37d83041828484840f2448d5b3e3770e46694f9)
License type: Commercial, build 2023-09-24
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [92% battery remaining]
Primary display: Intel(R) HD Graphics 530 (Intel) Memory: 1GB, Driver date: 8-20-2021 (M-D-Y).
- Windows Main Display attached to adapter port 1
Primary OpenGL: NVIDIA GeForce GTX 960M (NVidia) Memory: 4GB, Driver date: 10-4-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.58
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-4-2023
Driver Version: 31.0.15.3758
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.1.1.0
E:\Downloads\elefront411\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
E:\rhino3d\BoltGen\BoltGen1_62.rhp “Rhino.NET SDK” 0.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.34.23267.11001
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2020.12.7.446\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2020.9.1.565\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Rhino 7\Plug-ins\NamedPositions.rhp “Named Position”
