Latest v7 and WIP Points manipulation causing crashes
I can’t tell if what I’m seeing is a new bug (in both Prod and WIP) but SetPt is completely unstable (yes, I’ve uploaded files, sent countless crash reports). It’s not just SetPt, it’s any large scale manipulation of Points (Set/Distribute/drag) will cause a crash.
Hi @pharris65,
I’ve looked at the dumps you’ve submitted. But the information is inconclusive.
Is this something you can repeat? Of so, can you post a model and instructions on how to repeat?
Thanks,
– Dale
it crashes (conservatively) 8 out of 10 times I attempt to SetPt, or Distribute points -
manifold.3dm (19.6 MB)
Moved to Serengeti as the example file was created by V8 WIP.
well, yes and no. It was created in v7, I opened it in WIP 8 to try the distribute (on points), I can send you the same file in v7 and the set point crash will still happen
The file was last saved in V8 WIP. It opens in V8 WIP but not in V7.
What points are you moving? The file does not contain any point objects. Are you turning on control points and moving the control points? Or moving objects?
Hi Pete,
I cannot repeat your SetPt crashes moving the control points of your wires around. Can you give step by step instructions?
Regards
Jeremy
yes, last saved in WIP 8 (as I was testing distribution of control points), but SetPt causes same crash in v7 or v8 (Windows or OSX - x86 or M2 - all have been tested) and obviously distribution of control points in WiP crashes in all of the above mentioned machines.
Doing this will cause the crash
doing this will cause the problem
it’s Phil :slight_smile:
Just try SetPt the above or if running WIP 8 SetPt or Distribute (in x-Axis in above example)
it just crashed again and I sent the log doing exactly what I am describing in the thread
Sorry Phil! Dunno where I got Pete from.
I’ve grabbed various sets of control points and used SetPt X and SetPt Z half a dozen times and all working ok in R8. Can you give me step by step instructions? For example, I might select one position of control points across all wires. Are you selecting only part of the group? Or control points at multiple positions on multiple wires?
the diagram above (and the SetPt in the Y-Axis, for this instance) shows the points I was trying to SetPt that caused the crash I just uploaded
as for step by step, there really isn’t any thing I’m doing other than aligning/SetPt’ing and occasionally trying to Distribute the same Control points, sometimes it crashes, sometimes it doesn’t, but about 60~80% of the time is crashes
Hi Phil -
Please run the Rhino SystemInfo command and copy-paste the result here.
Mac Pro (Intel)
Rhino 7 SR27 2023-2-1 (Rhino 7, 7.27.23032.13002, Git hash:master @ 4a0030c0d354560df03764f4f49ecc5d119e5118)
License type: Commercial, build 2023-02-01
License details: Cloud Zoo
Apple macOS Version 13.1 (Build 22C65) (Physical RAM: 7.7e+02Gb)
Mac Model Identifier: MacPro7,1
Language: en-US (MacOS default)
AMD Radeon Pro Vega II Duo OpenGL Engine (OpenGL ver:4.1 ATI-4.9.51)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 32752 MB
Graphics: AMD Radeon Pro Vega II Duo
Displays: LG HDR 5K (163dpi 2x), LG HDR 5K (163dpi 2x)
Graphics processors
AMD Radeon Pro Vega II Duo (32 GB)
LG HDR 5K (2560 x 1080 @ 60.00Hz)
LG HDR 5K (2560 x 1080 @ 30.00Hz)
USB devices
Apple Inc.: USB-Serial (0001)
Chrontel: Billboard
SanDisk: Extreme Pro 55AF
LaCie: Rugged USB-C
Chrontel: Billboard
Logitech: Logitech MeetUp Speakerphone
Generic: OWC Thunderbolt 3 Dock SD Card Reader
Other World Computing: OWC Thunderbolt 3 Audio Device
Apple Inc.: Magic Keyboard with Numeric Keypad
Apple: Headset
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
com.paragon-software.lvm-for-mac (1) 0B3A024F-F646-30A8-9712-6743C3ADE51B
com.logmein.driver.LogMeInSoundDriver (411.22.3) 8107552A-78D0-30F3-B50A-D4D8A13C982C
com.uaudio.driver.UAD2System (9.15.0) no UUID
com.drobo.SCSI.ThunderBolt (1.4 [115880]) 9A7A78EB-7F61-39EA-A11A-9C239752C2F2
com.TrustedData.driver.VendorSpecificType00 (1.9.1) 1CE82B35-4312-3E6E-8E3A-48FA4C493895
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/Users/pharris/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Rhino 7/libkeyshot_rhino_plugin.dylib
/Users/pharris/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Rhino 7/KeyShot11RhinoPlugin.rhp “KeyShot11RhinoPlugin” 1.0.0.0
/Applications/Rhino 7.app/Contents/PlugIns/MPlane.rhp “MPlane” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_STL.rhp “STL Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_Points.rhp “Points Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_Points.rhp “Points Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_X.rhp “X Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_STL.rhp “STL Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_X.rhp “X Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Squish.rhp “Squish” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.27.23032.13002
/Applications/Rhino 7.app/Contents/PlugIns/Import_M.rhp “Import_M” 7.27.23032.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp "Export SVG” 7.27.23032.13002
MacBook Pro M2
Apple macOS Version 13.2.1 (Build 22D68) (Physical RAM: 96Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: Mac14,6
Language: en-CA (MacOS default)
Apple M2 Max (OpenGL ver:4.1 Metal - 83)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Apple
Render version: 4.1
Z-Buffer depth: n/a
Total Video Memory: 72 GB
Graphics: Apple M2 Max
Displays: Unknown (220dpi 2x)
Graphics processors
Apple M2 Max
Color LCD (1496 x 967 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
None
Third party plugins
/Users/pharris/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot9Rhino5Plugin.rhp/libkeyshot_rhino_plugin.dylib
/Users/pharris/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot11RhinoPlugin.rhp/libkeyshot_rhino_plugin.dylib
/Users/pharris/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot9Rhino5Plugin.rhp “KeyShot9RhinoPlugin” 1.4.0.0
/Users/pharris/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot11RhinoPlugin.rhp “KeyShot11RhinoPlugin” 1.0.0.0
