I’m using Rhino to edit some dwg file import, and I had been able to add line types and pick them from the drop down list, but yesterday after the latest patch, that function suddenly do not work any more: Adding new line types through custom option indeed added them in line types, but get nothing added to the drop down list in the object property window, and if you export back to dwg file, all those lines types revert back to default, even they appear to be working in Rhino
Hi Johny -
I can’t seem to reproduce this in a quick test.
Please post both the output from the Rhino SystemInfo command and a simple dwg file that you are experiencing this with.
system is i713700k and 5070ti, never had problem before, and there is another strange thing, when I saved all the files yesterday and closed computer, today when I open Rhino it says some of the files is not saved and it kept autorecover copy of that file, and to my surprise, the saved file had wrong line type, some lines totally changed spacing, but now I reverted to old version in July and it works so far.
The error I experienced can be done in a quick test: add custom line type in object property window, and check the “add to document line types” box, click “OK” and check the drop down list, it still does not have that added new line types, this happens before export to dwg, so something is already wrong in the workspace
