i have several problems of rhino stopping , at start , dragging a object , opening a file , not happy
Me to but with Grasshopper. So I uninstall SR2 to come back to the previous.
where to find SR2 ? as it is unstable now dragging a object made it crash…
https://www.rhino3d.com/download/Rhino/6.0/release
Currently, that will let you download 6.2.18065.11031
does not work says you have a newer version installed, i do not like
uninstalling 6 or should i ?
If you want to revert to an older version, then, yes, you will have to uninstall RH6.
worked ok did not have to install toolbars again etc
next time ill wait a few days…
Are we the only ones having trouble with crashing SR.3 ? i have it on 2 computers
Hi Rob - is this the case with any file? If not, can you send us an example? (www.rhino3d.com/upload)
thanks,
Yes with any file simple lines does it crash or more complex ,(at
opening when starting rhino mostly) but i did send a crash report , as
it crashed so many times so must be multi reports i did send (from my pc
or my laptop)
i have deinstalled sr3 and the previous version is working ok found a
crashdump will send it
grts
Rob
Hi Rob,
I see your crashes and have passed them along to the developer. Thanks!
Thanks sr3 was unworkable for me
Grts
Rob
This week’s SR3 won’t be any better; but I hope next week’s build will be.
Consider changing your update frequency (Options - Updates and statistics) to Service Release so you quit getting SR candidates.
Ok we just give it a try when available , it is not a big issue sr2
works ok as far as i can notice for me
grts
Rob
@robo -
I’ve seen similar reports from about 12 people, I think, and haven’t yet been able to reproduce the problem.
I made some changes in Rhino sr3 that may help or fix it, but since I don’t know how to make it happen, I don’t know how to tell if it’s fixed.
