Last update broke EditPythonScript?
ié just updated Rhino and it seems “EditPythonScript” is broken. Anyone else has the same issue??
Thanks!
Rhino 8 SR36 2026-10-6 (Rhino 8, 8.36.26279.07001, Git hash:master @ ac38d526d13733dca94ed9bebe1087ca27dc4ae8)
License type: Commercial, build 2026-10-06
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET 10.0.12
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 9-4-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 616.92
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-4-2026
Driver Version: 32.0.16.1692
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Hi nachetz,
Does this happen when you start a blank file or when running a particular script?
Do you use ironpython? There is a known issue in the last build that has been filed.
Try changing to .netcore 8 (troubleshooting only)
Hi!
it happens on blank files, no matter the script.
Yes i use ironpython. I’ve switched to NET Framework and now scripts run, just lost “RhinoGadget plugin” :face_exhaling:
Hi, the same thing happens to me—not just in “EditPythonScript,” but also when running a simple Python script that used to work perfectly. I managed to fix it, though, by using the “SetDotNetRuntime” command and selecting “V8”.
Hi -
This was caused by switching over to the .NET 10 runtime and has been fixed in an internal build.
I think the plan is to release a Hotfix for the release candidate.
→ RH-99401 IronPython scripts fail on the .NET 10 runtime
thanks for the info @wim
Where can I get the hotfix?
Sent
Hi, could you send me the hotfix?
Thanks!
Thanks Japhy, that worked. I assume that the new RC to be released today in the NA time zone (tomorrow over here) will also have the fix?
