Last release SR33 / Grasshopper Crash
Am I the only one having Grasshopper’s GhPython Editor crashing for no apparent reason
This is new with last release R7 SR33.
What is the best way to rollback to previous version ?
Regards
Hi @lahos,
Can you run the SystemInfo command and post the results?
– Dale
I tried SR32 and the bug is still there.
Apparently not related to the new release.
I also tried SR33 in safe mode.
A sequence to make Grasshopper hangs :
test.gh (3.3 KB)
  • Start test.gh
  • Open/Edit GhPython node
  • Press Test
Regards
-------------- SystemInfo
Rhino 7 SR33 2023-9-5 (Rhino 7, 7.33.23248.13001, Git hash:master @ 332dda7497b18e9e6f82f118da5cba0c448151a9)
License type: Commercial, build 2023-09-05
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 4-18-2018 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1070 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 1-15-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.24
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-15-2023
Driver Version: 31.0.15.2824
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\0.1.0.0\TeDaSharp_050.rhp “TeDAsharp” 0.1.0.0
S:\Code\Rhino\plugins\SafeLayout.rhp “SafeLayout” 1.1.0.2
S:\Code\Rhino\plugins\CSCommandOnKey.rhp “CSCommandOnKey” 1.0.0.0
S:\Code\Rhino\plugins\SampleCsDockBar.rhp “SampleCsDockBar” 6.0.0.0
C:\Users\HAL\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2020.3.5.0\7\Fologram.IO.Rhino3d.Win7.rhp “Fologram for Rhino” 2020.3.5.0
e:\internet\StereoView.rhp “StereoView”
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.33.23248.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.33.23248.13001
Hi -
That seems to work fine here.
Your title says “crash” but the instructions say “hang”.
I don’t see any crash reports from you, so probably something hangs? Is that just Grasshopper or also Rhino or the entire system? Is there any CPU activity in the Task Manager?
Sorry for the misunderstanding.
I used “crash” cause when it hangs the only thing I can do is to kill the whole thing.
Unfortunately there is no crash therefore no report.
It seems to happen only on my laptop.
My desktop computer “resists” to the Test button challenge :wink:
OK button does work fine.
I just updated my video drivers and disable all my Grasshopper libraries (.no6 files).
It still hangs and cpu load seems really weak (0.5 %).
Regards
Hi @lahos,
You will need to disable all of your “Rhino plugins that do not ship with Rhino” and 3rd party Grasshopper components. When GhPython is back to working normally, then put back the 3rd party tools one-by-one until you determine which one is causing the problem.
– Dale
Nailed it !
I found the faulty Grasshopper plugin : SolutionAsync.
It seems that it is not working anymore with GhPython since at least SR32.
It is weird though that my desktop computer never had a bump.
Thank you for your help.
Regards
