When using Lasso in Window mode, it will pick up all geometry except hatches.
When using crossing mode, it will pick up hatches
-Jeremy
-Jeremy
That’s because your Lasso selection is set to “Window” instead of “Crossing”.
If you select the Hatch and run BoundingBox, you’ll see the area that needs to be Window (surrounded) selected.
Either switch your Lasso to use Crossing selection or make your Lasso big enough to surround the Hatch BoundingBox.
