Hi. I am trying to achieve this effect:
I would like to apply it to a box.
Find the file in this post. The layer is " columna ".
I know I could make a 2D drawing and then intersect it with the “box” offseted several times. Then I will get the “cascade” effect.
So:
-Offset a 2D drawing several times
-Offset surface several times
- Intersect/trim/booleandif each correspondent 2d lines with the surfaces. Line1 - Suf1 …and so on
I am just thinking if there is a faster way to try more options in the drawing. I guess grasshopper will do the trick, but honestly I am not super familiaarized. If its not super complex I could give a try
Lightbox_test.3dm (2.8 MB)
