LARK Weather converting error
Hi all,
I am working on a parametric model regarding the daylighting of a room. I am using LARK to map the non-image forming effects in the room but I encounter an error that I cannot solve. When using the analysis period template a component regarding the weather file need to be run. However, when running the convert weather component it gives an error. The error states that it could not find the file but there is also no file created anywhere in my libraries that has short.wea. in its title. Does anyone what the problem can be in this case?
Thank you in advance!
Hi Jessie -
FWIW, I haven’t seen much discussion of the LARK plug-in on this forum. You might want to check their support forum on github or contact the author directly. You’ll find links to both of those from their Food4Rhino page.
