Hello
I’ve stumbled upon a strange problem while working on a pretty complex deffinition.
What it boils down to is that I have to compare two distances between two points and a reference point and I want to select the one that is at a distance greater than zero. Then I get this:
I then tried to replicate the issue and I have internalized the data and simply copied the relevant components into a new document. This gives me the correct result:
Any easy workaround?
problem.gh (7.4 KB)
This is the working *.gh file with the inputs internalized. I didn’t upload the original one because it is needlesly complicated for this, but I will add it if it is useful.
