Large no. of hatches in file causes crash opening doc props
I’m creating a template file for 2D drawings and imported around 900 hatches into the document to sort through totalling around 3mb of data. They import fine and display in the hatch properties menu although they run a bit slow but it’s perfectly useable. However, when opening the Document Properties menu Rhinos hangs for extreme periods and often crashes. Clearly, the solution is using fewer hatches but I also feel like given the hatch properties menu can deal with that amount of hatches there might be a bug with hatch display in the Document Properties menu that should be addressed.
Hello - thanks, I’ll check this.
