Large models not working - display pipeline/zooming/linked data/georef
I’m doing a project where the dataset is some 7000 km from the equator and some 500 km east of GMT.
I need to keep my files georeferenced. That is one important goal.
I have many files that are georeferenced. Many of them large meshes and large datasets. Many survey files.
I have building geometry that I want to work on in a file with Units = mm. Close to Rhino’s origo.
I’ve tried many different ways of managing these things in Rhino. Many many different ways.
It’s just very hard to manage.
Here are some takes on this nightmare. Please come with suggestions if you have alternative ways of managing such a diverse dataset.
I combined all georeferenced dataset into one 3DM file, all of them active blocks. At the moment the file is some 3-5 GB in size. Quite snappy to load and works fine. Meshes used in there are sometimes 8,5 mill triangles. Rhino handles them fine as long as they are not edited. Editing of meshes that size is very slow. Deleting one face or 1,5 mill faces takes approximately the same time.
Already in this file it is hard to handle the underlying linked blocks. Either they are active and create a mess in the Layer manager. Or they are just blocks with all that is inside hidden from the user. Not good.
Also, important, there is no way of keeping the block data out of the file. Rhino keeps all the linked blocks in the merged file. Making it 3-5 GB bigger than it needs to be. What a pity.
Well in the work file where the design is made, this georefed file is linked again as a block and moved from far away to local x=0,y=0. This works fine, but now the original files are two levels away and all the important information in those files is hidden and is hard to read/reach. Essentially those linked files are now just a bunch of layers that can be on/off.
Using the Worksession linking could be fine, but worksession files can’t be moved. They snap back to the original location. So that does not seem to be a good solution either when georeferencing is involved.
I also have very distant geometry (a mesh with 50x50 meters triangles) to use as a backdrop to study views from the designed buildings. Unfortunately the display pipeline can’t handle meshes that are 30 kms from origo. Meaning that either the distant geometry disappears or the local geometry disappears. So having this beautiful dataset of a mountain range, does not really help at all.
Some conclusions from this mess:
  • could linked blocks be optionally stored on the side, not in the main file ? That would keep work files small as the blocks then would load only when needed? Or we could have a flag = keep loaded.
  • could we have a more structured way of how linked blocks present their information in the Layer manager? Especially the Active type of blocks is a mess, presenting actual block and layer structure in two different places. Also not clearly marking that those layers are from a linked block.
  • could all the data residing in the blocks be available but (naturally) locked? Meaning that every geometrical object can present it properties even if it is two levels of linking away? I mean, if you can see the object (lets say a point), you should be able to know its properties … Isn’t that quite obvious? If the point is on a Layer called “Ground” in the original file, that property should be available to the user.
  • could the layers of inserted files be “active”, so that they can be modified in the main file? It can be relevant in a complex environment to change the layer colour, transparency, display mode etc. That would help a lot and make Rhino so much more powerful.
  • could worksessions be moved, scaled and rotated when being linked?
  • could the display pipeline somehow be improved so that it does not fail to display geometry when it is both very close and very far away? Maybe there could be a display mode (or a setting) that would degrade quality / speed, but allow the user to actually see all geometry at the same time? It would be of great help. I noted that for the worksessions there was function LimitReferenceModel that limits what is displayed from a worksession to limit the amount of data displayed. (I understand the underlying problem of floating number precision when using 32-bit signed number and huge distances … But surely their must be a way of doing this, albeit at a cost.)
As it is now I have given up doing this in a structured manner as it does not work one way or another. I’ve just given up having the relevant information in the work file. I look at the combined georeffed file when I need information. I open the linked files if I need to access object information. I keep an origo translated version of the files I need most and I link or paste that file into the workfile when I need to.
It would greatly improve the final result if all of this could be accessed in the Layer manager. It would be marvellous.
All the best
/Erik
Erik -
Part of the game here is coordinates. Yes, I understand the Georeferenced goal. But, if the building model itself is truely georeferenced out far from origin, the detailed geometry of the building, say rails, walls etc will struggle to intersect accurately.
Essentially, the computers have 16 digits to work with, which only about 8-10 of them or reliable with heavy duty intersection calculations. So, try to stay down to 8 digits in the measurement values.
For land models this can mean meters is the units needed. But for buildings with constructed detail, sub mm may be needed.
I normally will place the building close to 0, then use the Rhino Basepoint command to put the basepoint out at geo referenced location. Then the building is close to 0 in its own file, btu will line up with the land reference when inserted.
When linking blocks are they being inserted with Linked and Embed or just linked? The linked and Embed will read the whole block into the model.
This is a difficult thing to manage.
