How can I modify or I don’t know delete locales files to get only English here:
That’s an error message that comes out of the .NET framework, which probably means it uses the Windows OS locale.
I was afraid of that, thanks anyways.
Hi David, my gh shows error messages just in german. is there a way to get error messages in English language at least in the gh python component?
I found an old post where you gave some hint about error messages in c, https://stackoverflow.com/questions/209133/exception-messages-in-english , but i am not sure how to get access to those classes in python.
This is based on your Windows’ main GUI language, you need to change it to English
I have that same problem with my workstation.
HI, thanks for the reply. I understood that, but because I cannot change my Window language I wondered if there was another way round.
Unfortunately there isn’t.
At least I couldn’t find any other way.
Perhaps this should be changed inside the code of Rhino where the Python engine is embeded. That it should ignore Windows GUI language and use Rhino’s language. @stevebaer is this possible?
