I made the wall with a boolean difference in order to feather the 4" x 6" notch at the top of the landscape wall. The command worked with doubling the tolerance however when I use Rhino Inside to bring the wall into revit it works but in a 3D view the wall goes transparent when zooming in. Is there a way to fix this?
Example file ?
2020-07-20_L1_NW_RIBBON WALLS (2).zip (9.1 MB)
Here is the revit file for your review.
Thank you
Steven Shkolnik
818-355-5155
Seems like the tolerance in the corner is causing issues. Try splitting the wall on that line and bring it into Revit or simplify the corner geometry
Thank you I will try it and let you know
Revised_L1 NW PODIUM RIBBON WALL 7-20-2020_7.3dm (3.7 MB)
I tried simplifying the curves on the cutting piece - the Boolean difference worked much better and I was hopefull - but the same problem. I will try cutting the wall at the corner thought the goal was to feather it.
Cutting the wall at the corner did work.
Thank you
