I dont know if anyone is able to help or suggest any ideas. I have these kinds of series of planes and surfaces at varying heights, is there a way to kind of apply some kind of grouping or rebuilding command that could help me make this into a hilly landscape, basically a way to merge all these planes at varying heights and stuff into one kind of landscape that has these undulations and elevations etc. Any kind of way you think I could accomplish this would help.
Other than that I am trying to model a landscape with different undulations, depressions, elevations etc, anyone have the best commands, workflows to accomplish this.
Hi @Kaamil_Hasan_Dahodwa
Since you provide no details at all on slopes, scale or intended use, my guess is as good as any - but I’d probably go for Sub-D to get smooth transitions between the various levels. But again - you might be looking for something completely different.
Another approach would be to use Drape with a fitting spacing (and probably some more geometry to fill in the “empty” areas, so that the draped surface doesn’t “drop off”)
Post a more detailed description, reference pictures or whatever you have - and of course the 3DM file - if you need more competent help.
-Jakob
