Lands Design Forest Combine elements in grasshopper
Hi
Is there any way to programmatically generate Lands Design Forest elements with combined species?
Hi @David_Manango
What do you mean by “programmatically”?
When you insert a forest, you can combine different species with this setting:
From the plant species list, you will be able to edit each plant species individually inside the forest.
This option is also available in Grasshopper, if this is what you are looking for. You just need to create a forest with more than one species:
Thanks, it worked :slight_smile:
Hi @fsalla,
Is there also a way to adjust the distribution pattern in grasshopper for the forest option?
Hi @David_Manango I’m afraid there is not. We may implement this option in future versions.
The other option is to insert the plants individually from points, with the desired lists and distribution patterns, instead of using a Forest.
One needs to write Grasshopper algorithms on their own.
