Land Objects on a landscape
Hello, I’d like to know if there’s a command to make my little flying cubes land on a landscape. I have several geometric shapes above my landscape, and I’d like each of them to land directly below it. I hope that’s clear enough. Thanks!
I use this script:
ProjectVolumesToSrfs.py (7.4 KB)
Select the volumes (they can be meshes or surfaces, but must be closed), then the surfaces or meshes to project onto. Option to project objects “On surface” (first point that touches stops) or “In surface” (object is fully inserted into the terrain).
Hi Helvetosaur, thank you very mutch, it works perfectely, it’s magic ! Did you write it ?
OK, glad it works for you! Yes, I wrote it.
