Laging when shift for angle-snap?
Hi!
does anyone have a clue where this lag comes from? i havent had this much lag before and now its hard to work when i have to wait everytime i press shift for a quick rotate.
Hi Wilhelm -
Do you have, or have had, multiple files open at the same time? Does this behavior persist when you completely quit Rhino and then start a single new document?
Hi!
Yes its persistent, its been with me for a week approximately.
Wilhelm Broman
+46 76 204 39 06
Hej Wilhelm -
Please run the Rhino SystemInfo and copy-paste the output here.
Rhino 8 SR7 2024-5-17 (Rhino 8, 8.7.24138.15432, Git hash:master @ 03702f889bdef32626af4bca510b5e8a85666d38)
License type: Commercial, build 2024-05-17
License details: Cloud Zoo
Apple macOS Version 14.5 (Build 23F79) (Physical RAM: 64GB)
Mac Model Identifier: MacBookPro18,2
Language: sv-SE (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
U32R59x (3840 x 2160 @ 60.00Hz)
Color LCD (2056 x 1329 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/wilhelmbroman/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/KeyShot2023RhinoPlugin.rhp/libkeyshot_rhino_plugin.dylib
/Users/wilhelmbroman/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/KeyShot2023RhinoPlugin.rhp “KeyShot12RhinoPlugin” 1.0.0.0
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.7.24138.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.7.24138.15432
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.7.24138.15432
Hej Wilhelm -
It sounds like this issue was reported as RH-82080.
This one appears to be fixed and the first Rhino 8.9 Service Release Candidate that should get released a few hours from now should work better for you.
Note that you will need to change your update frequency from Service Release to Service Release Candidates to get this 8.9 release.
Thanks! That did the trick :smiling_face:
