Hi all,
I couldn’t find any topic with the same problem as i have.
I am using Rhino 5.0. I have a problem of rhino pausing for seconds after every little command.
for example if i draw a polyline, once hit enter, for 1 seconds it is ok, but after 1 second there is a freeze/ for 2-3 seconds.
the freeze or pause gets longer if the file is heavier.
its happening with a 70mb file which is not that big…, and other colleagues with lower spec workstations actually don’t have the problem with the same file. if i start a new file, it is ok, but eventually i will have the same problem.
can anyone please help?
(I have a Intel Xeon CPU E5620 2.40 GHz (2 processors) 16g RAM.)
