I’m working in mm and I’m doing some radiation analysis.
I always have to set my models to meters instead of mm, otherwise ladybug will crash.
Has anyone else encountered this?
Thanks!
Thanks!
You should probably report that here:
https://discourse.ladybug.tools/
As far as I know, Ladybug should work in mm and Honeybee components should automatically be scaled when you let the bug fly. Then again, they keep on telling users to use meters by default - also because this is the unit system of EnergyPlus and Radiance.
