Lack of persistent 3d dimension tool
Yes, it would indeed be useful. The inconvenient thing, if I may say, is that the DimCurveLength command does not update unlike the other dimension commands.
In this case, I’ll show you a practical example. When I create a development of a sole, all the length, distance, and angle dimensions update once the “Scale” command is executed. The only dimension that I have to redo each time is the DimCurveLength because it never updates, and it’s a bit annoying, honestly.
DimCurveLength updates fine here on a fast test.
which Rhino Version are you using ?
maybe post systeminfo.
Rhino 8, In Rhino 7, it was the same as well.
I just performed a non-uniform scale in Rhino 8, but the elevation did not update; I had to execute the command again.
As you can see on the left, you can still see the old elevation, which remains the same despite performing a scale operation. On the right, you can see the new elevation measurement.
All the other dimensions, instead, update without any issues.
This is my workstation, but at home, I work with a €4000 PC and I have the same issues.
Rhino 8 SR8 2024-6-18 (Rhino 8, 8.8.24170.13001, Git hash:master @ c3cc7c123163b65d85b517aff795627d5b12166b)
License type: Commerciale, build 2024-06-18
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1050 Ti (NVidia) Memory: 4GB, Driver date: 1-18-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-18-2024
Driver Version: 31.0.15.5123
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\XNurbs (80be33b0-13b2-4ac4-9c77-03829214f9e9)\6.1.1.119\XNurbsRhino7.rhp “XNurbs”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24170.13001
can you post the file or at least the dim-part of it ?
maybe my fast testing was not complex enough.
Try copying a sole and scaling everything using the non-uniform scale command, and you’ll see that the other dimensions update while the DimCurveLength does not.
Per Scala Non Uniforme.3dm (1.4 MB)
if I scaleNU the first piece “46” the length updates.
if I do a copy of it, and scale the copy - it does not update.
Dimlength refers to an object ID, and this ID is just copied. (not updated)
so if you do a copy the dimlength still refers to the initial object.
this looks like a ugly limitation - that is easy to understand from a developer perspective but completely unintuitive from a users perspective.
is this the problem ?
if yes the workaround would be:
draw a initial object with all dims.
scale that object
copy the scaled version to the final position
scale the initial object again…
or work with 2 documents - which will support a second undo/redo stack.
do a single scaleable object with dims in a first “interactive” document. scale it, copy it, undo.
past it to the final second “static” doc.
does this help ? kind regards -tom
Okay, thank you, you’ve helped me understand where the issue lies in Rhino (ID). But then why not make the DimCurveLength command work like the other dimensions (update)? In my workflow, I hypothetically design a sole, heel, etc., starting from a base number like 37 for women and 42 for men. Once I create the sample and dimension it, I copy the entire layer—say, from size 46 to rename it, for instance, to size 49. Then I develop the object using Non-Uniform Scale. Everything updates except for that dimension command. In the end, if I have to repeat too many operations because DimCurveLength doesn’t update, it’s faster to re-dimension. Still, thank you for explaining the problem to me.
Maybe this script helps a little (but it’s not persistent)
Some time ago, I posted two alternative ways to build 3d dimensions in Rhino, even though they were not exactly what a true native 3d dimension should be capable of. I will try to find them now.
Two macros for creating of a vertical dimension or aligned dimension directly in the Perspective viewport:
  • 3-D vertical dimension
    ! _CPlane _Object _Multipause _Dim _CPlane _Undo
  • 3-D aligned dimension
    ! _CPlane _Object _Multipause _DimAligned _CPlane _Undo
This video shows how to use the 3d dimensions:
A proposal from 2019:
Another important thing to consider:
check out the macro I posted above - it might have some advantages - even if it does not come with a nice colorful video.
@Gijs
@brvdln
started a related topic
which is more or less the resume of what I 've been writing
cheers -tom
I tried it numerous times, but I can’t get a nice dimension between two end points.
3d dimension build.3dm (176.7 KB)
run the macro
click (1)
click (2) - 3 times with some mouse movement in between to get a dim without distance
It’s not vertical, though. That’s the goal of having 3d dimensions in the Perspective viewport.
I use this macro, which allows setting a custom inclined plane:
! _CPlane _3Point _Multipause _DimAligned _Multipause _CPlane _Undo
ok - i see
try this:
_CPlane _3Point _pause _pause r0,0,1 _dim 0,0,0 _pause _pause _CPlane _Undo
violet result
If you are just needing to check a distance and aren’t trying to specifically draft something, you can always use the distance command.
I hear your frustration. managing complexity is difficult (just look at how much apple struggles with their settings) when you need to balance things working while also giving functionality. All those options exist because people use them. There is not one “just works” tool unfortunately. Even the simple tasks requires you to make dozens of decisions, conscious or not, and the program will have to make all those same decisions. You can’t just default your way around many of these problems because there not default condition that covers even 50% of cases.
If having a single simple use command, you could make a macro that would reduce all this stuff to one command. But you would be hard coding in all the decisions you make. That command would probably save you a lot of time.
Something to remember is that the developers do actually watch the forum and are responsive. They also care about the product. We could be in the hell scape that is AutoCAD with dozens of broken features and command and no simple way of doing anything.
Is there a way to eliminate the need to click for the 2nd end of the dimension? Similar to this proposal:
In my opinion, there could be just 3 mouse clicks:
  1. Mark the start of the vertical dimension;
  2. Mark the end of the vertical dimension;
  3. Set the height of the dimension (must support snapping to objects or entering a numerical value for the height in system units).
Alternatively, there is another similar proposal:
  3. Set the angle of the dimension (must support snapping to objects or entering a numerical value for the angle in system units; press Enter or RMB for vertical).
  4. Set the height of the dimension (must support snapping to objects or entering a numerical value for the height in system units).
… sounds more like a script then a macro…
… with a lot of creativity there might be a workaround, to somehow macro-rize it…
Your macro is almost there, just needs to eliminate picking the end point of the dimension, because it’s already set by the 2nd mouse click, which marks the orientation of the CPlane.
Making it dependent of the History recording (updating the 3d dimension after dragging one of the objects it’s attached to) is probably something that can’t be made via macro.
yep… but as the 2nd mouse click is first for the _cplane command, then the same coordinate is used for the next command _dim the macro somehow needs to save / recall that input.
I dig a bit - but did not find a workaround, like somehow insert the point-Coordinates twice, from a point that is drawn (and later deleted the point by the macro…)
and the cplane command can not be called recursively…
… scripting is the way to go…
