@nathanletwory
Thinking loud: why settings above do not correspond with those below:
Ground plane from options panel takes a priority over the ground setting from side panel. It is confusing and hard to find where is the problem.
@nathanletwory
Not sure what you meam, both screenshots show the same values for the same settings…
If you switch off ground plane completely in a side panel it is still on until it is switched off in display properties via options panel.
Also, I made them look exact but try to play with ground plane in Arctic mode. Nothing is changed unless you adjust itvia options panel.
The proof:
A bit unintuitive indeed. This is controlled by the Custem / Render Settings setting:
Arctict is set to Custom, so that always overrides.
Logged RH-64095 Confusing ground plane handling for improvement.
I have figured it out before but it wish these settings were linked. Far easier to control the scene.
