I’m trying to count a bunch of geometry and label it. If I had for example an array of 100 circles and I wanted rhino to generate a label for each with a sequential number how would I go about doing that?
Hi Owen, you might try below python code for a start:
import Rhino
def circle_filter(rhino_object, geometry, component_index):
if isinstance(geometry, Rhino.Geometry.ArcCurve):
if geometry.IsCompleteCircle: return True
return False
def LabelCircles():
msg = "Select circles to label"
ids = rs.GetObjects(msg, 4, True, True, False, None, 1, 0, circle_filter)
if not ids: return
height = 1.0
font = "Arial"
font_style = 0
justification = 2 + 131072
for x, id in enumerate(ids):
curve = rs.coercecurve(id, -1, True)
rc, circle = Rhino.Geometry.Curve.TryGetCircle(curve)
if not rc: continue
text = "MyCircle {}".format(x+1)
rs.AddText(text, circle.Plane, height, font, font_style, justification)
LabelCircles()
c.
I’ve got Mac Rhino here at work and it’s not playing so nice with python at the moment. I’ll try it on my windows version tonight. Thanks though.
