Kuka PRC help with Multi-Axis movement
Hi guys, I have a script which I would like some help with, I want to print in multi-axis using KukaPRC Add-on, I already have a script with normals aligned with the curvature, however the robot is not correctly following the path, I want to know if anyone has any experience with this kind of operation or can help me understand what I am doing wrong.
This is the toolpath of what I want to print:
This is how the vectors of the toolpath points look to enable multi-axis:
And this is the issue with the robot + error:
Here is the script:
Robot messup.gh (20.3 KB)
Thank you.
did you setup your Tool and KUKA position correctly?
it looks like the arm movements are pretty convoluted…
you might also want to internalize Tool geometry
Hi @Jess_Tanturro,
I’m the developer of KUKA|prc - I don’t always check the various forums, but send me a mail at johannes@robotsinarchitecture.org if you run into issues.
As @inno mentioned, it would be good to be able to access the full setup including tool geometry for more efficient troubleshooting!
Best,
Johannes
Hi Johannes,
Thank you for paying this some attention, I have sent you an email regarding this.
Looking forward to hearing from you.
Hi Jess,
I just replied via mail, but in case it also helps others I’m also posting it here!
The logic is fine, just the planes were set up in a way that is not ideal, and for reachability you should orient them to the robot.
I’ve modified the example a bit!
Hope that helps!
Robot messup_2.gh (20.0 KB)
Best,
Johannes
Thank you Johannes, very informative.
