I am just starting rhino 3D tool to design a kiwi fruit mould with dimensions 8cmx5cmx5cm. Need to make two more pieces, one a bit larger and the other slightly smaller (+/-0.5cm in each aspect). Could anyone help me to design that?
Thank you very much for the response.
Here I am attaching the picture of a kiwi fruit for which I am willing to create a mould with dimensions 8cmx5cmx5cm. I also need to make two extra pieces of mould, one a bit larger and the other slightly smaller (+/-0.5cm in each aspect).
Why you just not take a phone camera, take multiple photos and use photogrammetry to create a 3D mesh from that using RealityCapture or smth similar.
Then you can import such geometry to Rhino and simplify it?
Thank you for the response. I am very new to Rhino or 3D modelling. I am attaching the 3dm file which I have hands-on so far to create not the exact mould for kiwi but something with similar shape. Hence I selected the ellipse with 4mm x-axis form centre and 2.5 mm width on y-axis. Later I added surface creation with “Extrude straight” with height 2.5 mm… Now, I want to create its mould which should not be exact as a replica of the kiwi (as shown in the second picture attached), but somehow similar in shape. The kiwi fruit I am just taking as reference. Please provide some suggestion or help on this.
I have performed some fillet edges at both side of curve(attached the 3dm) but i want this to look more like oval such as the kiwi, Please suggest how can I do it?
Thank you for the advise and direction all the people here. I believe i have experimented much to prepare the mould and sharing the file here. Please provide the comments and suggestion. I appreciate the prompt response and the wonderful suggestion of people here.
Thank you everyone.
For the created KIWI mould i need to write some text such as Kiwi on the surface and then substract from the surface, how can i do that. Here attatching the 3dm file and also the png file (the text place is indicated by the arrow). Plesae help me to do that.Kiwi_1_Q.3dm (7.2 MB)
