Kiwi 3d - shell element with holes
I’m trying to find the shape of a bent shell in Kiwi w/ a load displacement curve. The simulation runs fine using non-linear analysis for the surface without any holes in it. When I add holes, the simulation doesn’t give proper results. I’ve tried increasing the surface refinement some, but rather than just guessing and waiting for results, I thought I’d reach out.
This is the result with no holes:
This is the result w/ holes:
I’m open to doing this with kangaroo (or any other way), also, if it’s faster and easier.
Here is the grasshopper file:
lamp.gh (58.5 KB)
Thanks in advance!
Hello. I’m not a developer of Kiwi, but I suspect Kiwi does not support trimmed surfaces (i.e., holes).
It works with loads and linear analysis, so I thought it would work with displacement curves and non-linear analysis.
After much trial and error, I was able to get it to work by reducing the polynomial degree to 2, increasing the iterations, and setting the U & V divisions to 15.
