Any tips about how to avoid/adjust the kink at the end of a crease?
Erik
Erik
I believe there is remove crease tool under the “Subd” category that could help, otherwise you need to weld the edges together, which is another tool in that category too.
I believe you’re looking for a variably sharp crease transitioning from sharp at one end to smooth at the other. This is filed as https://mcneel.myjetbrains.com/youtrack/issue/RH-54305 currently. You can use SlideEdge to move edges closer at one end of an edge to make the appearance of a sharper area in the meantime without actually adding a crease.
Thank you, but remove crease will not help, since I want a crease. It is the kink at the connection of the creased/non- creased edge that I do not like
T-splines had a more smooth transition at this point.
Thanks Brian, I will play with this work around.
Erik
