Hi guys,
I have started using Keyshot 8 lately, I am having a problem with syncing Keyshot with Rhino.
When I hide an object in Rhino and then update the link on Keyshot there is no problem as on Keyshot the object is hidden. The problem arises when I make the object visible again on Rhino and update the link again, the original assigned material is not saved in Keyshot and I have to add the material again.
Do you face this problem? If so is there a fix for it?
Thank you.
Adonia
