Does anyone know where the double secret probation list of keyboard shortcuts or Aliases is buried?
Tools- options aliases
Thx. But how would I know what characters to type into the Command macro column to make this work? In other words, hovering over the line icon pops up “Single Line”. But typing Single Line into the Command macro column fails as an Alias. Where is a list of all the command macro’s that actually work?
The command line shows what happens when you activate a command, that’s what aliases feed into, there is likely some documentation somewhere about these “command macros.”
Okay, so the command line provides a hint… sometimes. Seems like there should be a published, alphabetized list - especially with all the new v8 commands.
Have you looked at the Rhino documentation? The command line is not a hint aliases literally are fed into it as you can read out.
Note that making an alias to “Line” seems like a waste of time since you can just type li-enter, as is really most customization.
Line was just an example. Perhaps you’d like to explain where the macro is for showing 4 viewports in third-angle projection.
Just shift+right click on the button and there it is…
