The f keys work. For example f11 is Onenote. F2 is volume down .
I can use it as is by typing POn for now and esc to turn them off. Thank you for trying
Hi Mark - do you have the v7/WIP? Do these shortcuts work there?
I have the one (WIP)you all sent out earlier this week. And it also does not let me turn on points by f10
OK - thanks - very strange - A couple more questions… - is there a ‘Fn’ key on your keyboard? If so, does holding that down allow the Fkeys to work in Rhino? And, is there another keyboard you can try? I understand it should not matter since the keys work in other apps, but just to make sure…
Yes !!! It works while holding the fn key. What’s up with that? In the WIP it also works while holding the fn key.
There may be some setting for this in Windows so that it is not needed…
some info here:
I guess I wasted a whole bunch of your time. It was the FN key lock. It works as expected after holding the FN key and F10 then lock.
In my haste, I probably hit FN while trying to escape sometime yesterday.
Thank you, Mark
…learned something…Thanks Pascal !
I’m just the messenger, I had to kick this upstairs, @JohnM had the fn key brainstorm.
