I had a Rhino 5 keyboard macro " ! _RelocateGumball " that relocated gumball. Worked fine in 5. Does not work Rhino 6, even though this one from 5 did work " !_Gumball T " that turned Gumball on and off. I used the RelocateGumball often in 5, can someone help. Thanks
Hello - in V6, GumballReloacate
… I guess to allow autocomplete to gang all the Gumby related commands together.
I don’t understand, sorry. Is there a fix?
There was a name change between v5 and v6
RelocateGumball \Rightarrow GumballRelocate
Thank you
