I’m experiencing some very frustrating issues trying to use the keyboard inside Grasshopper using RhinoInsideRevit, where the keyboard focus keeps being stolen by Rhino even though Rhino isn’t on screen. I’m afraid I don’t have a great set of steps to reproduce but the behaviour looks like this:
Start Revit (2019)
Start RhinoInsideRevit
Open a Grasshopper window (without opening a Rhino window)
After a few minutes trying to use keyboard shortcuts or type in a Panel in Grasshopper results in the keyboard input going to the invisible Rhino window - you can see the autocomplete dropdown from the Rhino command line appearing over the top.
If I actually open the Rhino window and put on another monitor it’s even clearer - I can see the input going into the command line.
In the Rhino command line I can see the error “[HotKeyHandler] | WARN | Could not claim hotkeys. Another CAD process is unresponsive.” being spammed continuously by something.
If I try using the Windows On Screen Keyboard I get the same behaviour.
This is with the versions below - this is a WIP version of RhinoInsideRevit but I was experiencing the same issue with 1.12 stable as well.
Rhino.Inside Revit: 1.15.8571.17168 (2023-06-20T09:32:16)
Rhino: 7.30.23163.13001 (Rhino 7)
Revit: 2019.2 (20220111_1110(x64))
CLR: 4.0.30319.42000 (4.8.4644.0)
OS: Microsoft Windows NT 10.0.19044.0
Usually using a laptop screen, two external displays through a USB-C dock and another display on USB-C (so four total) - although usually I would spread Revit/Rhino/Grasshopper out this happens if everything is on the same monitor.
The issue still occurs if I load without external plugins.
