I can’t get a keyboard event to trigger. I’ve also noticed that the “KeyboardHookEvent” doesn’t exist on the right in the script editor. Is it no more?
As always thanks a bunch Dale. I’m now just figuring out if I should attempt to make this in Python and if it will actually work. I think I’ll answer my own question if I play around enough.
But it’s inaccessible in the “new” API docs and technically missing information.
I was confused about the Delegate signature because most delegates are of the (object sender, EventArgs e) format. Having the key as the only argument makes things a lot easier.
It works in C# (but…). I could not get the Python code to work after quite a lot of experimenting.
And the “but”: It recognizes the C# but sends the program into an infinite loop. Overall the behavior is quite erratic and I don’t think this approach is useable unfortunately. I’ll have to think of something else, perhaps the command line string capture?
