Is there a way to keep the camera from orbiting in orhographic views? I have it set to plan mode, and the projection is parallel, but I keep accidentally orbiting. It used to work like this when i started using it (a year ago), but now, I’m orbiting in all ortho views. Thanks!
Hello - a plan view of a CPlane should not tumble with RMB drag but it will with the RotateView command. How are you tumbling the view? You can set ‘Always pan parallel views’ in Optiions > View page but that is more restrictive.
I accidentally tumble if i accidentally click alt + middle mouse button (I’m toggling heavily between Maya and Rhino, so my navigation gets screwy). I do have “always pan parallel views” checked. I don’t use rotateView at all. It wasn’t always like this.
Hello - testing here, I have two Logitec mouses that, so far, behave differently from one another - one works exactly as expected and as you expect, and one does nothing useful at all on MMB-drag - it just slightly changes the zoom level. This last is thew fancier mouse, with more stuff on it, but I cannot so far get it to obey the MMB setting in Rhino. I can set a side button to behave like MMB however… In any case, panning is consistent when it happens - it does not tumble an ortho view. What mouse do you have?
OK, here, with the second mouse that behaves as expected, I now see plan views tumble with Alt and that is indeed the expected behavior with the settings you show.
Are you able to give it a setting so that the camera doesn’t tumble in ortho view? I can imagine many users would find this useful to lock in ortho views so they don’t behave this way. Thank you!
-Lia
