Hello all,
I’ve extracted a list with all the texts in a file and got only the ones who matched a pattern.
Now I’m struggling to keep the same index of the first list…
Can someone help me?
Thanks!
recup points topo.gh (169.6 KB)
Hello all,
Thanks!
You didn’t upload your Rhino file so I can’t really test this, but think this may be what you are looking for.
-Kevin
Thank you for your answer but no, in fact I want to filter a list (the one of the texts) using only the values in the field Match Text, but keeping its original item numbers.
Here’s the .gh with internalized curves and a .csv file with the values (I could’n know how to internalize the texts in Rhino…).
altimétrie.csv (21.2 KB)
recup points topo intern.gh (273.1 KB)
If I understand what you’re asking, you want to extract the values that match your pattern and maintain their index numbers. I don’t think this is possible - list indices always run from 0 to 1 less than the number of items in the list. I suppose you could replace the items you don’t want to keep with nulls.
The CSV file you uploaded has all numeric values with the exception of 3 lines. Some of the values do not have a decimal point or following digits.
Feed the “text” output of your script component to a Text component (Params → Primitive → Text) then right-click the Text component and select “Internalise data”.
You can build more flexible search patterns by using regular expressions as I have shown here.
text_matches.gh (32.0 KB)
-Kevin
