Is it possible to keep all the adjustment parameters of the shapediver viewer from the previous uplaod (visible / hidden parameters, shadow yes / no, automatic extended zoom, rendering environment, ground plane etc …) to avoid re-entering when re-uploading the GH definition
At the moment, the only settings you can keep are viewer settings. When you upload a new model, you can select a previous upload to use the same settings. However, in our upcoming platform update it will be possible to copy all of these parameters from one model to another one. On top of that, some additional control regarding parameter grouping and ordering will be available directly inside Grasshopper.
Beta testing for the new platform is now imminent, we will keep you updated when those features can be tested.
Thank you for your answer !
