So Im getting to my first sword blade series scultping and couldn’t go to the straight forward blade, had to do a Katana…
I did the profile, mapped it on a curve to create a loft that works nice but i need to scale sections of the blade to a degressive curve. Curve mapper right? Im trying to make a degressive curveon the Z scale of the lofted profiles of the blade on the length of the curve but it come out funny no matter how i try…
It’s a matter of the point you’re applying the scaling factor from. It is empty, so by default grasshopper uses the World XY Origin. If you turn your geometry to the side, you can see that the funny profiles sit below the 0,0,0, so they scale upwards (towards 0,0,0) instead of downwards, which is the expected result.
I would explode each profile, order the vertices by Z value, and use the lowest as the scaling origin, this means that each profile would have their own origin.
