Karamba3D Model to Revit
Is there an all-in-one component that can export a Karamba3D analyzed model into Revit?
Thank you!
Hi Johnny,
Geometry Gym can facilitate this, probably using a couple of components or steps.
There is a Karamba to IFC component, that can export an IFC file, and then either you can import the IFC into Revit using the Geometry Gym plugin (user interface). We did get a prototype of a Rhino.Inside.Revit component if you are running this way (it facilitates the same steps, without user intervention).
This will work better for skeletal models, such as steel. In Karamba a floor or wall is likely meshed into lots of finite analysis elements and it’s unlikely you want a slab/floor for each of them. If this is the case, it is possible to prevent area elements and inject in the underlying source of these.
Cheers,
Jon
