I have been trying to find a way to retrieve the plane representing the local coordinate system of an element using C# (looking for the same output as the GH-component Disassemble Element - LCoSys). I hope somebody could help me!
I found several leads in the API documentation:
- the method “BuilderElement.disassembleElement”. This seems to return the things I need, but I have no clue how this BuilderElement class relates to the ModelElement class-elements that I can grab from Models.Model.Elements(). How do I access the BuilderElement properties and methods for ModelElement objects?
- I found that the ElementState class has a property called .Coosys. But there doesn’t seem to be a method like “GetElementStates”. Only thing I found is the .GetCrossSectionsStates_OLD, that returns objects of class ElementState_OLD. This does work but considering the “OLD” extension I have the feeling this is not the way to go.
- I also tried this piece of code, but it returns Null Planes:
var model = modelIn as Model;
IEnumerable elem = model.Elements();
List listofPlanes = new List();
foreach (ModelElement e in elem)
Vector3? vecNullX = e.x_ori;
Vector3 vec3X = vecNullX.GetValueOrDefault();
Vector3d vec3dX = vec3X.Convert();
Vector3? vecNullY = e.y_ori;
Vector3 vec3Y = vecNullY.GetValueOrDefault();
Vector3d vec3dY = vec3Y.Convert();
Plane myPlane = new Plane(new Point3d(0, 0, 0), vec3dX, vec3dY);
listofPlanes.Add(myPlane);
A = listofPlanes;
