Karamba Support with index 3
I have a problem with the setup for my supports in Karamba. The message says:
  1. Solution exception: Support with index 3: There is already a support defined at the same position.
ValeKaramba.rar (2.4 MB)
Vale Karamba (1).gh (47.8 KB)
Hi @camiarce.ch
you need to flatten the input in the Remove Duplicate Points component. Karamba will calculate but you will get inaccurate results when you have multiple supports at the same position.
