Karamba - Moving Information Through Python Node
Hi there,
I’m using Karamba as part of a parametric structural design tool.
I’m trying to choose between two support types depending on a simple true or false variable.
I tried writing a python code using a simple IF statement:
However, the support information changes when going through the python node:
Is there a simple way to achieve what I am trying to accomplish?
I’m not an expert in either grasshopper or Karamba!
Appreciate if anyone can give me any assistance with my problem.
Thank You
Dylan
I think it’s related to the automatic unwrapping of GH_Goo<T>
This could work: make the IF statements using Python to output 0 or 1 and use a Stream Filter component to select what sort of support is used.
The problem is caused by the missing wrapper, see the attached definition.
Karamba3d_PythonWrapper.gh (4.7 KB)
Hi Thanks for your help.
I tried running the definition you attached however I get the following error:
Not sure why this is?
I think this solution will be very relevant to a few other scenarios in my script so appreciate the advice.
What happens when you write
y = Karamba.Supports.GH_Support()
instead?
What version of Karamba do you use?
Best,
Clemens
Hi Clemens,
I’m current running Grasshopper 9.0076 and Rhino 5 with Karamba 1.2.2
When I remove the input ’ x’ I get the following error:
it’s hard for me to guess what’s wrong since I can not reproduce the error on my machine.
The exception comes from the panel, so ‘karamba.Support.GH_Support’ is basically available. It seems like ‘x’ has the wrong type, however ‘Support’ is the correct type. That is strange.
Try to unhook the ‘Memory load *.GHA assembliew…’-option under the ‘Grasshopper Developer settings’.
Do you get the same behavior with Karamba 1.3.0?
Best,
Clemens
