Karamba Joints?
Hello @all,
i need some help in setting up the right references in my karamba model. The Substructure needs to follow the deformation of the Main Structure Elements. Therefore i have pluged in the divided curves into the inclusion points of the mesh breps component.
But in this case the substructure base points are in dependency of the deformated beams.
So are joints the solution for this case?
thanks in advance
kev
hi, there are too many external plugins to load the script, but it seems like that there are supports at those positions. Please check this
okay so instead of creating the elements each i know got them through the mesh edges, similar to this video here: Grasshopper Tutorial- Part19- Beam Structural Analysis with Karamba (A Complete Guide)
once i got them differently and get those support points from the mesh everything worked somehow :smiley:
