Karamba blocked by KarambaIDEA StatiCa
I recently downloaded KarambaIDEA_StatiCa a Dutch app, just to check it out, supposing it was just an add-on or plugin. However, it now occupies the K tab in Grasshopper such that I cannot get a clean Karamba anymore.
How can I get rid of it? I have contacted the support for this software and asked for instructions to uninstall but they don’t seem to know either. Any idea?
Thanks, Ingemar
Hi, unfortunately we are unable to help you here, but maybe someone from McNeel might assist if you also add screen that shows the the problem clearly.
Hi Ingemar -
If you installed it with the PackageManager, you should be able to use that to uninstall it.
Thank you Wim,
It worked fine with PackageManager; I got Karamba back - clean!
Ingemar
