I am currently trying to display the moment diagram in Karamba but I am having issues displaying the values at the maximum positive and negative moment locations. I have the “Numbers” icon activated on the Beam View Component as you can see in “Capture2”. However, in “Capture1” I still do not see the values displayed. Any ideas as to what is going on here?
Also, how would I go about displaying the section forces in Rhino along different points of the beam other than where the maximum occurs?
there is no image attached, but if you are changing the image resolution, the text actually does not scale up, but rather stays at the same size while the image itself is larger. This might be why your text is not visible.
