I’m experiencing a minor issue with Karamba. When I attempt to extract the deformation energies of 2050 elements, I obtain only 2046 values as an output… (see screenshot) this is strange since in other cases I can have 2067 elements and get 2067 values. Does Karamba automatically cull null values, or eliminate values which are equal? Can I stop it from doing this? I’m sure there’s quite a simple reason for this…but I can share my script if needed.
Nobody can see from the screenshot what went wrong. Upload your Definition.
In the bottom, you trim tree and list item, may there something went wrong?
Apologies; my internet connection is terrible so it takes a long time to upload the files (see updated post above). Hope the definition allows you to better visualize the problem; it appears a bit random since as mentioned above, I repeat the same operations elsewhere without issue.
