Karamba 2.2.1.7 Beam View
I’m studying from the tutorials, I had the karamba 2.2.0.8 version and the curve output from the beamview component was working fine. But for the newer version Is not passing any information. How can I enable it?
If you need to check I’m doing it with the zollamtssteg bridge files
Hi, in the newer versions, the Beam view component has been superceded,
This means that you should just replace it with the same component.
