Kangooroo for a hexagone surface
Kangooroo works fine with a 4 point surface.
But it doesn’t work when i apply a 6 point surface
any idea ?
If you post your file I’ll take a look. Looks like the way you’re defining the surface doesn’t give points coinciding with the corners.
To make a hexagonal membrane from quads, an arrangement like shown here can work well:
Thanks yo very much
i pretty new into this word
i use the standart poyline operator, and the deconstruct Brep to extract verticles (corner)
Hexagone.gh (12.0 KB)
I use you methode by using WbsplitQuads, it works as charm,
thanks you
