I have a rigid body suspended on 3 wires. Load is applied to the rigid body’s centre of mass. I wanted to speed up the calculation by meshing the brep as it made the rigid body (RB) component run faster. But that gives incorrect reaction forces - sum of all three reactions is several times larger than it should be.
I want to see where to the objects swings. For now, I’ve replaced the complex brep with a simple representation and used show component to pass the RB¨s plane into the simulation. That way I can move the original body to the final position. But then I’m redoing a lot of work the sim already did with the (substituted) body.
Has anyone had a similar issue?
